Disable Z axis homing
Discussion in 'Controller Boards' started by gmhudson, Aug 21, 2023.
  1. gmhudson
    gmhudson New
    Is there an easy way to disable Z axis homing (at the same time as maintaining Y2 ganged to X axis)?
    Or to disable Z axis entirely (I have none, but if the Z axis buttons are pressed it wakes up the X and Z steppers …).
    thanks
    Which controller do you have?
  3. gmhudson
    gmhudson New
    X32
    On the X32, running grblHAL, you can
    Set $44=1 to home X first
    Set $45=2 to home Y after
    or
    Set $44=3 to home XY at the same time and
    Set $45=0 (currently has value, clear it with a zero)
    Additional or extended settings
    Setting $1=255 is advisable to keep motors always on - Step Idle turning the motors off can cause loss of position Grbl v1.1 Configuration
  5. gmhudson
    gmhudson New
  6. gmhudson
    gmhudson New
    Ok thanks, works.
    I’m turning the steppers off to avoid any possibility of burning out motors or board at the moment … it is worrisome hearing them humming when stationary …
    The context sensitivity / mouse over help for the settings seems to be intermittent btw (I get no help for these settings at the moment, for example).
    thanks
    For that to happen the motors would have to be electrically incorrectly spec'ed, or driver current set too high. Its designed to be always on
  8. David the swarfer
    so long as you can hold a finger on a hot motor for 5 seconds they are not too hot
