G02 Full circle
Discussion in 'General Talk' started by Søren Weitling, Oct 23, 2022.
  1. Søren Weitling
    Hi
    Anyone that could point me in a direction so I can read and understand the syntax of G02 full circle for GBRL 1.1
    Thanks in advance
    Grbl prefers it as two half circles - can't find the link right now but its somewhere in the Grbl Wiki or old Issues
    Søren Weitling likes this.
  3. Søren Weitling
    Thanks a lot. Two half circles explain already a lot :) I will look for it in the Wiki
  4. David the swarfer
    Do not use R format, only I J K format for arcs.
    While R will work most of the time, there will be times when it does not work and will try to do the 'wrong side' of the arc, usually an enormous arc that causes crashes and other chaos.
    Do not try to do arcs that are smaller than 1mm radius. Again, sometimes they will work, but often they will not.
    In our Fusion360 postprocessor arcs that are smaller than certain limits (absolute chord length and also related to tool radius) are always linearized.
  5. Søren Weitling
    Thanks David :)
