No Power to Cool Output
Discussion in 'Controller Boards' started by Tim Smith, Sep 20, 2022.
  1. Tim Smith
    Tim Smith New
    Hi all,
    Just received my new led light ring and router mount. I tested the led light ring by going to straight ot the 24v. power supply and it works just fine. I went ahead and installed the leight ring and issued the M8/M9 commands and nothing. I verified the wiring connections and nothing. Everything else with the blackbox is functioning as it should and runs jobs just fine, just not the cool output. Any suggestions as where to look next?
    Thanks,
    Tim
    Please check if with the store via Support > New Ticket for assistance
  3. Tim Smith
    Tim Smith New
    Before I do that quick question, I went ahead and pulled the top off of the blackbox to do some needed cleaning and I noticed there is not aq jumper on the M8/M9 pins. There is for the M3/M5 should there be for the cool to work?
    That's for the Relay, no bearing on the Coolant output. Learn more about that jumper here: docs:blackbox:jumper-relay [OpenBuilds Documentation]
    You can wire LED ring power via the Relay - but we'd prefer support look into your order - if there's an issue with the BlackBox you'll likely get a replacement
