Projects cut in reverse?
Discussion in 'CNC Mills/Routers' started by msmuggs, Nov 24, 2021.
  1. msmuggs
    msmuggs New
    New to OB, drawings come in the 3d window properly and simulate properly, however, everything is upside down and in reverse when my machine cuts?
  2. sharmstr
    Go into grbl settings and change $3 to invert X and Y directions.
    msmuggs and Peter Van Der Walt like this.
  3. David the swarfer
    Axis directions must be like this
    ie, the relevant axis moves in the + direction when you jog +
    actual X0 Y0 may vary depending on how you set up the homing.
  4. msmuggs
    msmuggs New
  5. msmuggs
    msmuggs New
    Thanx!
