      1 votes
      This is a design for my LR/BS CNC router.
      I wanted an easy to source/easy to build, yet quite robust CNC router.
      I must say I'm very satisfied with the result.
      With a footprint of 750mmx750mm, the working area is of approximatively 480mmx600mm, with 80mm of Z travel. The machine can easily be scaled.
      The design uses linear actuator with two HGR-15 and one SFU1605 ballscrew for each axis (2 ballscrews for the Y-Axis). The ballscrews are fixed on both end using BK12/BF12 blocks. Each axis is driven by NEMA 23 motors.
      Plates are 3D printed (with reinforced side plates to avoid flex) but can also be cut from wood/aluminium if you have access to a CNC router.
      The frame is made of transverse 20x60 V-Slots in order to use vise clamps (OK-Vise or Mini Vise - CNC Low Profile Clamp by ptiwee). Wood planks slightly higher than the V-Slots (3mm) serve as martyr.
      Motors are assembled using 3 9mm spacers, which should be rigid enough.
      The Z-Axis uses two crossed linear rails. It is a heavy design that can be improved later, considering many existings Z-Axis design can be adapted.
      Previous version using MGN-15 rails :
      LRBS.png Frame.png Motor Coupling.png Z-Axis.png Z-Axis (Back).png Z-Axis (Mounted).png
      18/11/2020 UPDATE:
      The build is finished. First cut are promising. BOM, DXF and STL are realease. The build cost me around 800€, + router.
      15/09/2020 UPDATE:
      I updated a bit the design for easier assembly and reinforced the side panel so that they can be 3D printed. I will publish the BOM and DXF as soon as I validate this new design.
      7/5/2020 UPDATE:
      I beefed up the machine. MGN-15 rails seemed to be quite weak for a heavy duty machine, and have been replaced with HGR-15. The linear actuator have been reinforced with corner angles. They are now made of 1 20x80 V-Slot and 2 20x40 V-Slots. Aluminium plates have been thicken to 15mm. FK12/FF12 blocks have been replaced for BK12/BF12 which allows for bigger work area.
        File size:
        445.3 KB
        2,915
    I wanted to upgrade from my OX CNC. Workbee CNC looks like an interesting upgrade, but V-Wheels are not rigid enough (the main issue with my OX CNC is the flexibility in the Z-Axis), so why not trying linear rails and big ballscrews ?
