I took a Lead 1515 kit and cut two of the supports to 49.5" and rotated those to the x-axis. Then built a platform that could hold the frame and the rest of the CNC machine. This allowed me to add the accessory board so I could do dovetails and other box joints. I did have get more single angle brackets and another x-axis support for the y-axis drag chain.
Build in 'CNC ROUTER BUILDS' published by Merltech, Feb 23, 2024.
Mark Carew likes this. -
Build Author Merltech, Find all builds by Merltech
I built this so I could have a larger format cnc and the ability to cut dovetails and other box cuts.
