      1 votes
      Here's my Hot Wire Foam Cutter now with updated software and firmware.
      Full details are on my website as well as an eBook with plans, instructions and a parts list
      How to build a Hot Wire CNC Foam Cutter - rcKeith
      The build of the CNC hot wire foam cutting machine isn’t difficult measure twice and cut once as the saying goes. The website has the build instructions, plans and main parts you’ll need as well as the cutting lists. The controller board and the stepper I’d recommend you buy as a kit including the power supply. Loads on eBay, just search for a 4-axis CNC kit. I’ve included all the details of my machine so if you follow this you should be able to build your own.
    Hot wire cutting by hand is OK but requires many templates which take time to make. So I built this CNC hot wire foam cutter to eliminate the templates. I always wanted to build a CNC machine but never though it possible. If I can do so can you.
    Youtube seeing what was possible.
