Say Hello to my little friend.
Work Area app 300x300
Twin OpenRail Carriage on the X-axis with triple pylon beam support on either side uses 48v to drive 570 in/oz motor attached to 2 to 1 timing gears driving 4mm pitch ball screw drive.
Y axis has 3/4" aluminum table sitting on SBR12 linear rails driven by 48 v supplied to twin 570 in/oz motors with 2 to 1 timing gears and 4mm pitch ball screws.
Z axis 170mm travel on solid v-wheels uses 48v to drive a single 400 in/oz stepper with 2 to 1 timing gears and 4mm pitch ball screw.
H-100 1.5 KW VFD Inverter driving a 1hp (750W) spindle motor.
Heavy Metal
Build in 'CNC ROUTER BUILDS' published by Brian Slee, Aug 30, 2023.
Many Thanks to ThatJim for helping me with cutting all of the plates for this build
Charles Prest, that-jim, backwoodsbob and 1 other person like this. -
Build Author Brian Slee, Find all builds by Brian Slee
