The FARM OX is Dual mode/function 4 axis rotary machine (X,Z,A & C) based around two C-Beams. 1000mm and the 250mm. This machine would be controlled by MachineKit powered by a BeagleBone Black.
To be more specific, a BBB with a DB25 Cape to an 4 Axis Driver board. And teamed up with a small 5~7” Touchscreen to as as a DRO, Control & Status of the machine.
The last image is a strip of addressable LEDs which will be directly controlled by MachineKit via a custom HAL. It will be use to provide normal lighting and visual status messages of what the machine is doing. i.e. slow pulse green - 'Status Ready'. slow pulse yellow - 'Feedhold'. Hard flash red - 'Error'. etc.
The scope of this project is to design & build this machine, configure MachineKit- And make a pre-made image that has the correct profile (config/tuning file for MachineKit) To make it ready ‘Out of the box’ so to speak.
This is a WIP. I am still working on a couple of adjustments to make assembly easier. And there is a couple parts I still need to model in.
More info will be provided soon.
FARM OX (Four Axis Rotary Machine)
Build in 'Other Lathe Build' published by ymilord, Aug 19, 2015.
Four Axis Rotary Machine (FARM) OX. Equipped with a X,Z,A & C Axis.
Amito, Andy247, Frank Ruhl and 40 others like this. -
Build Author ymilord, Find all builds by ymilord
Multi-Rotary goodness.Inspired by
Multi-Rotory Axis Milling/Machining -
