A build made only with openBuilds hardware and a printed part to hold the E3DV6 extrusion tool.
Electronics is the traditional Arduino Mega 256 with RAMPS 1.4 and RepRap discount display.
Auto-levelling is achieved with a BL-Touch.
I had a little problem with this one, sometimes when the pin is moved up it goes down immediately and the BL-Touch is in error. I had to tweak the Marlin firmware to handle this as when it happens, auto-levelling is bad and you have to restart the whole process after having manually stopped the print.
I had tried a chinese E3DV5 hotend but finally I bought an official E3DV6, I wasn't convinced by the quality of the copy.
To lighten the X axis that supports the printhead, I'm using a Bowden hotend.
Another 3D Printer using OpenBuilds Hardware only
Build in 'Cartesian Style Bots' published by TronixMaker, Jan 6, 2017.
A light 3D printer made of OpenBuilds hardware only
RENGY, Tomas Pontes, Robert E. Nee and 2 others like this. -
Build Author TronixMaker, Find all builds by TronixMaker
- CERN (CERN-OHL1.2+) Open Hardware Licence
I've built this printer because my first one was 6 years old (a Reprap second generation) and the quality of the prints was not always good. Moreover, the bed levelling was really a pain.
As an Open distributor, it was a good opportunity to use the OpenBuilds hardware.Inspired by
OpenBot (OpenBot)
